You were running 15psi without your timing retarded at all? Damn, you really just hate your car don't you? Now, after all that abuse, you want to go the cheap way and not even get the head resurfaced? Not having money is more of a reason to it. Do it right the first time, so you don't have to spend money a second time when it goes wrong. Not that it matters, with the way your treating your car, that engine won't last long at all. Keep running 15psi on that T28 with stock timing and a metal headgasket. You will be posting more problems soon. I tried to point you in the right direction, but your obviously not interested.
Luderacer14 wrote: Ok, I was just wondering why it bogged when it got from 13-15 psi before it blew. Could it be my MAF maxing out?? My wideband reads perfect, I'm running a 12.7 all across. It's a T28. Anyways, I already have my metal headgasket on order and I still gotta save up for the stupid boostdesigns clutch and flywheel. My engine still starts and runs, i feel the air push out from the headgasket everytime it turns. NO water at all. I'll post once I get it all fixed and running again, it sucks that I'm carless and it especially sucks that I can't race it!!!! Ohwell, my timing was'int retarted too, any of u guys think retarding from the distributer by itself is good enough. It's .5 degrees for evey psi right? Anyways, I'm probably not gonna have the head resurfaced because of $$$ issues. It did'int overheat so I'm good right?? The T28 is a fun turbo and had no lag compared to my stock gst, I don't know about u guys, but I don't even think I have lag, but eventually, I'm gonna go for a t3/t4 for bigger power numbers.
