navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Wed Jun 02, 2004 3:30 pm
try spraing out the maf with brake cleaner, dont use carb cleaner though.and dont hit the hot wire directly with spray, its really sensitive. have you pulled the ecu and checked for codes
if you aiv is bad, the maf will likely have soot all over it. i just used an empty CO2 cartrige from a bb gun to plug mine up, never had a problem since.
