Car bogs and blows fire out it's *** when boost hits high.
240SicknessX
Car: 96 240 SE
2d-ink wrote:Just out of Curiousity does a SAFC and VAFC have these Anti Stall System that you can run a Open Atmosphere BOV with out your car stalling? I'm asking more towards a VAFC because I have one sorry if I kind of push this out of topic
yea you can run a atmospherically vented bov with the safc or vafc, the air decel settings adjust the amount of fuel that is supplied as the throttle is released at certain rpms. adjust it for less fuel when you let off the throttle, so your car dosent over richen between shifts or when you obruptly let off the throttle. this will keep the car running while the already meterd air has been purged from the intake track.
Jookmasta
still check the plugs altho the problem is fixed......
