Fla240sx »
https://forums.nicoclub.com/fla240sx-u71754.html
Sat Oct 06, 2007 10:16 am
yeah nothing else will go bad.........
check fluid levels in transmission/rear end cause they could leak slightly....
check coolant as well..... should be good tho, however u never know
the oil could break down etc, as it gets gas in it etc.... gas doesn't like to live too long and gets nasty..... so I would change the oil, fuel filter.. which has gas in it... and then if possible, drain gas tank or if its empty, put 10 bucks in it- burn it all out, then fill her up with fresh goodness.......
but your igntion system should be good and all that stuff..... I don't see a need to change any of that unless there is a problem down the road... that type of stuff either works or it doesn't
