Just noticed you put RCA 17ft X 2
Thats your problem, your deck has 2 outputs right? One is for your door speakers, and one is supposed to be for your sub. (they both give out different signals, so they should be labelled)
Use one set of rcas and run them to your speaker amp, then split those 2 connections with 2 of these (youll now have 4 connections for the speaker amp)
http://www.knukonceptz.com/pro...-1F2M
Then run the other rca output from your deck, straight to your sub amp, no daisychaining bulls***, thats how your gonna blow your equipment
Thats my guess, but you said this stuff was all working at one point when wired like you have pictured? Unless youre not telling me something
