Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Feb 14, 2005 6:24 am
I've never installed a metal headgasket before, but 80 lb-ft sounds too high for a SR head. The manual says ultimate torque after stretching the bolts properly is 25-33 lb-ft plus two turns 90-95 degrees.
Also, on a normal headgasket you don't use gasket maker, but I've seen multiple people use gasket maker on metal headgaskets because they don't seal leakage as well as a stock headgasket would. Would someone please confirm that last statement?
