car all ways smells of fule
Magic_man
Car: computer games
i just got the 240 about a 3 weeks ago and from the first day i got it. it has reaked of fule my mom and dad dont let me park it in the garge cuz i smells so bad is it something wrong with my car or do a lot of 1989 240s just smell bad?thanks chris:help
Cyberkreig
Car: 1993 Nissan 240SX SR
is the smell more intense when driving? You probably have a leaking injector or fuel line. If it was a fuel line, you would possibly notice a puddle of fuel. a leaky injector will usualy stain the intake manifold around it.
Magic_man
Car: computer games
ok thanks man ther is no puddle of gas but would a leaking injector all so make me run rich as well thanks for the help
Cyberkreig
it could, depends on what is leaking, if the injector isnt closing properly and is leaking fuel into the motor that will make one cyl. run rich (i had this happen after i installed a Walbro hi-flow pump). The injectors also have o-rings on them that occasionaly go bad, this leaks fuel out onto the motor, creating a stain.
1dollar240
Quote »The injectors also have o-rings on them that occasionaly go bad, this leaks fuel out onto the motor, creating a stain.[/quote]
Occasionally? ha, i've had my car since june 02 and have already been through three sets of o-rings. and if by "creating a stain" you mean a black, charred burn mark on the firewall from when the leak burst into flames, then you are right on the mark, at least in my case. I guess I'm just lucky.
BLiTz
Mine did the same thing, and i took it to my friends dad, a nissan tech for 25+ years, and his advice was a new fuel filter and plugs, and its true, runs alot better...check and see if your fuel filter is a nissan filter, if its not (like mine wasn't) its crap and replace it, and if you have anything other than NGK plugs, neplace them, these parts from Nissan was like $23 so its worth it. Does your car idle crappy, if not then its probly not the injectors, thats what i was told, so if it idles fine, then everything is fireing and your prob ok, my opionion, hope this helps:D
Cyberkreig
1dollar240 wrote:Occasionally? ha, i've had my car since june 02 and have already been through three sets of o-rings. and if by "creating a stain" you mean a black, charred burn mark on the firewall from when the leak burst into flames, then you are right on the mark, at least in my case. I guess I'm just lucky.
wow. I didnt know it was that common. Mine went bad cuz i put in a high-flow pump on the stock regulator =/. I guess that just goes to show, dont take fuel problems lightly.
C-Kwik
Check the gas cap. Make sure it is sealing. After driving around a while, the tank should build pressure. When you open the cap, if it is sealing, then you will hear a small rush of air as you open the cap. This is one possibility.
d240t2
If it is an 89, it probably is a leaking injector. SOHC 240SX KAs are notorious for having leaky injectors past ~80K miles or so (depending on numerous factors).
Dennis
fast_s13
it's the injectors i have a 90 and it had the same prob.. i changed the o-rings and doesnt leak or smell like gas anymore..i aloso found a couple bad vac lines
Calvin
The injectors can leak out through the seams in the metal body, among other places. This is a common problem with the sohc injectors. Sounds like your o-rings are fine, but your injectors are shot and need to be replaced... before you burn.
