Cant Start Car! (red top sr20det) Help!
F7Flare
Car: s13 sr20det
ill take any advice on this
recently when i start my car there is this sqeaky starting noise and one night i couldnt start the carso i replaced the battery the next day and its started up again but again with this sqeaky noise, this was about a week agoand juss last night my car wouldnt start again, im not sure what it could be, all the lights arent working so im thinkn something isdraining the battery, and i want to fix the bad start up noise as well.
let me know what you guys think
motoman399
Car: 98' wrecked (RHD coming soon) 240
sounds like alternator to me. you said you put in a new battery and then after a while battery lost charge? and squeaky being your alternator maybe???
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
yeah, sounds like a bad alternator, or your alt belt is not tensioned enough (loose belt will squeal/squeek). check the tension, and maybe pull the alternator and have it tested.
F7Flare
Car: s13 sr20det
now when i put the key in the on position nothing happensno dash lights turn on (the small red ones) or anyelectronics worki had just recharged the battery for over a day and nothingi also checked the ground wire and that was fine
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
with something like this, theres not much for us to do but give suggestions. gotta go through and recheck everything that was hooked up. could be as simple as a loose ground somewhere or a internal wiring hell. gotta start searching and looking over, checking fuses, testing amps, volts, test the starter, battery, alternator, etc etc.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
theres a ground on your alternator, make sure its hooked up. check belt tension because thats probably where your squeaking noise is coming from. Check the 75amp alt. fuse in the fuse box behind the battery. Check that the ground for your negative cable is tight on the inake manifold. Check all other engine grounds.
F7Flare
Car: s13 sr20det
nissans13240sx wrote:theres a ground on your alternator, make sure its hooked up. check belt tension because thats probably where your squeaking noise is coming from. Check the 75amp alt. fuse in the fuse box behind the battery. Check that the ground for your negative cable is tight on the inake manifold. Check all other engine grounds.
would the ground on the alternator not being connected drain the batterybecause when i removed the alt the first time to get it checked it wasnt connected, theres no bolt for it to be put on
