cant shift into gear while running
ray2009g
Car: 95 300zx m/t
have changed clutch master and slave and bypassed the damper with a new hard line now I have about 2 to 3 inches of dead play in the clutch and still wont disengage. how do I adjust the clutch or do I need to replace the clutch help..
nissanfreak12
Car: 92 300zx 2+2 TT
Go under the car and see if the shift fork is loose. It is possible it either popped off the pivot ball or the ball broke. That would cause a dead spot in the clutch.
It also could be possible the pressure plate is toast, but either way you will have to drop the trans.
Hackysac300zx
Car: 93 Nissan 300zx 2+2 N/A (TT motor in the works)
93 Nissan 240sx Vert (restoration in progress)
could be a throw out bearing...
