doctorj240 wrote:The same thing happens to me. My air bag light on the console flashes as well. I have no blown fuses, I've checked all connections on the steering wheel and can't find anything wrong.
You probably have a bad clock spring. What you should do is hit up someone with a scan tool that can check your codes for air bag system. If you have an open circuit code for drivers air bag module I would say replace your clock spring and see if your problem is solved.
side note: when replacing anything in your air bag system. Disconnect your battery from both posts. do not start working on the system till it has been disconnected for at least 10 mins. This will give it time for all capactitors in the system to drain down. then when you are done putting it all back together hook the battery up and reach in from under the steering wheel ,keeping your head away from the air bag, turn your ignition switch to the on position. This is just a saftey precaution incase something was done wrong.
