CANT REV PAST 5000 rpm !?!?!!?!?
FZ240
m 240 wont rev past 5000 rpm what is the problem here?
also i wanna chip/exhaust show me some product
frsh13
Car: 1991 240sx coupe
check out the brm exhaust that has a sticky above...also check the sponsor forum for a good deal on an exhaust
Chezedik
Car: 1991 Nissan 240sx
pop the cat, see if it gets better. Also, more info couldn't hurt. But if it just falls flat on it's face, the car gets cold or it sputters, sometimes a cat can be to blame. Start the car and run it until it reaches operating temp. Take a rag and grab the exhaust pipe, if it feels cool, tap it. If it is cold enough to touch (it will still be warm), but you can hold it without getting burned it may have a bad cat, basically at that point pop the cat, and see if the problem goes away. Unless, it feels like it is cutting out (hard) or bouncing off of the limiter, there is a good chance of this (in my opinion).
FZ240
ok thanks bro i was thinking of doing that cuz when i rev the motor i can hear this loud *** noise DIRECTLY under the center of my car on the left side must be the cat im thinking bout gutting it after i got my down pipe thanks alot bro take care
Chezedik
No prob, I hope it helps. Good luck!
Stigmata
Car: 92 240SX Fastback
Do you have a aftermarket intake system? If so that is your problem you must properly plug in most of the hoses,dont leave any behind accept the breather
