cant remove those 2 da** bolts
kilo13
i tried to remove those 2 bolts from the starter but it didnt even move one bit.could anyone give me a trick or suggestion?thanks
Mameluke
work out.
is it rusted or stripped or just plain tough? try getting an extension for your wrench or somethin
BadMojo
Car: 2007 Mazdaspeed 3
Try some PB Blaster or equivalent penetrant oil?
black s13
air tools.
gabossie
Car: Your mom
It can be done, it's just really difficult, especially the top one. You need a few extensions and a beefy contortionist. Some penetrating lube would help too.
kilo13
thanks for all your help.
Titan
Penetrating lube is overrated in my experiences.
One method always works, no matter what.
Get a 2 foot long pipe that will just fit over your rachet, slide it over, and pull at the very end. Leverage is your friend. Either you will crack the bolt loose, or snap it.
BadMojo
Titan wrote:Penetrating lube is overrated in my experiences.
Or, use a breaker bar and you get to keep all of your teef. ;)
Actually, I've found that PB Blaster (dirt cheap) and a breaker bar have solved all of my stubborn bolt problems.
black s13
or just use an impact gun. takes those bolts off in a very few seconds
kilo13
good news, i got both of them of a moment ago.thanks for all the help guys
crzycav86
Car: 93 Nissan 240SX KAT
BadMojo wrote:Or, use a breaker bar and you get to keep all of your teef. ;)
werd. be careful if you use extensions or else you could lose your teeth, or be like me and bang your head.. twice.. :(
black s13
i had to get 3 stiches :) 900lb/ft gun+ U-joint+ 19mm socket= pain. right between the eyebrows... i got lucky.
