flying_monkeee »
https://forums.nicoclub.com/flying-monkeee-u16444.html
Sun Apr 12, 2009 5:37 am
You don't need to pull the motor to remove the transmission, lol. Get a FSM or something...
I've had the same problem recently... chances are since you removed your dampener, you put too much stress on the pivot bolt, in which you will have to remove the transmission anyway. Removing a transmission is no biggie, just have some friends help you out when you remove it.
I would replace the clutch if it's the clutch that your motor or car came with when you bought it. It's never a bad idea to change it out anyway.
Opt for a NISMO pivot bolt, they're around 50 bucks i think... I can't remember. I have one and it's great. They're stronger than the OEM shiz.
If it's not the pivot bolt, it should be the slave cylinder. If all else fails, it's the master cylinder.
