210boostpimp »
https://forums.nicoclub.com/210boostpimp-u177912.html
Thu Jan 27, 2011 10:52 am
i'm about ready to pull my f*** hair out. i can't figuere out why my ca wont stay warm.
the car is a 74 datsun b210, with a ca18det swap. the car has a stock motor with the following mods. mandrel bent three inch exhaust, custom cold air intake, fmic, nismo adjustable fpr, booting about 11 pounds, electric fans. this little beast runs perfect other than the fact that it does not want to hold temperature.
here's what it does. if i let the car idle the temp will go up to 215 and then the fans kick in and cool the car down to 190. the car will do this all day long. after the car is fully warmed up i drive the car and temperature starts crashing down to under 100. the gauge starts at 100. i have pulled over to see if the fans are turning on before the temperature hits 215 and they do not. i have changed the thermostat three times. two from kragens and one from autozone. i ordered the stat for a nissan pulsar se 1987, temp is 180. the radiator is 27 inches by 19 inches, with one inch horizontal core (this was my vets old radiator). the fill line on the radiator is two inches above the thermostat. it has 50/50 coolant water mix. i have also replace the temp gauge twice. i don't belive its the gauge becuase the air coming out of the heater is not even luke warm at best. i dont even run the heater beacuse it will take longer to warm up.
i don't know what to do and it's really cold right now. should i try a stat from nissan? or???????????
