I can rev the engine past 3000rpm without problem. Right now I have the plugs gapped to .8mm.Tictakman wrote:can you sit and idle and rev up the engine? past 3000 rpms?
from what it sounds like you may need to gap ur plugs smaller, do u know what they are gapped at currently?
what is the order of ur intake system?
fliter-turbo-ic-maf-bov-throttle body?
This might be the problem. I did put silicone around the maf when I first put it on but I wasnt able to get it on certain parts because it was already mounted. I also just noticed that my vacuum at idle has gone from 20 to around 15 now. I might have a leak at the maf. The maf is reading fine so I might just need to seal the housing better.Blown240sx wrote:Blow through sounds to be the problem. The blow through setups have a big tendensy to leak boost or destroy the MAF. Id say its leaking boost at a certain point or the MAF is wiggin out.
Carl, what did you do to your maf to hold boost? Did you do anything other then sealing with silicone?Carl H wrote:yah ive found that most mafs will need to be 'boost prepped' to hold any ammount of pressure.i blew mine apart when doing a light throttle load and didnt notice it till i stopped and happened to look in the fenderwell and see that the cover was nearly off.
