Cant get hot air to stop out of defroster vents /Vaccum issu
A home for 1983–1989 300ZX owners!
GilroyZX
Car: 1984 300ZX
I have a 1984 z31 2-seater coupe, automatic, non-turbo, that I replaced the Heater control valve and the two small hoses (attached to this valve) located at the firewall next to the battery and am getting it ready for my daughter to take to school this fall, however now there is constant hot air blowing out of the defroster vents and I cant get it to shut off regardless of what I put the controls too.
I thought that the Vacuum tank (located by the passenger side headlight ) might be bad due to a fitting being broken so I replaced that with one from a wrecking yard but due to the amount of time that the car has sat and me not marking them (vacuum lines) like a dummy I can't figure out the 3 lines coming out of the Vacuum tank and how they connect to the control valve, etc. I'm figuring that the problem that I'm having is related to a vacuum issue since it was working fine before I replaced the leaking heater control valve.
Also does anyone have a picture of the heater control valve and the 2 water hose connections which are mounted on the firewall next to the battery that I replaced? Just want to conform that its hooked up properly and eliminate a reverse hook-up. I doubt that since the hoses are very short and are formed so that they only should only go on as connected however as usual take a picture or mark before ripping things apart is what I'm telling myself, anyway one is connected to the firewall and the other is to a tube that comes out of the block.
Any advice, pictures, or assistance would be greatly appreciated since its been over 100 here in Gilroy, CA and with the heater blowing the car is no fun to drive.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
This is a very common issue with the Z31, the vac line leading into the cabin near the battery provides the vacume t the system, th distribution block and actuators are located i top of the trans tunnel under the dash next to the gas pedal. Most often eihr the main vac lne is cracked and broken and no vac gets to the dashposts or the dash pots themselves have dried cna cracked and will to hold vacume. I have also found that sometimes the dashposts just stick ifthecar has sat for a logn time a hand vac pump will likely free up y stuck dashpots.
this ight help
http://www.xenonz31.com/hotairfromac.html
Return to “300ZX (Z31) Forum”
