cant get her started
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
ok cant get the car started95 s14 w/ a s13 redtop in
getting fuel only getting spark on cylinder 1swapped coils and all coils work on cylinder 1
how do you check the power output stage?
or does this problem sound familiar?
VigVoodoo
Did it run before?
Warped
no just installed it
VigVoodoo
So the coils only work on the 1st cylinder coil plug, right?
Warped
correct
VigVoodoo
OK check the hilighted connections.
Warped
ok f101 and f24 are for what?
VigVoodoo
Look at the diagram. F101 is the ignition coil harness plug. F24 is what it connects to. F24 is part of the Main Engine Control Harness.
Modified by VigVoodoo at 1:14 PM 5/17/2006
Warped
well arll are connected
VigVoodoo
Check this
Modified by VigVoodoo at 1:32 PM 5/17/2006
Warped
i'll check right now , thanks for the help man
Warped
nm that , the power output stage it ok
Modified by Warped at 3:45 PM 5/17/2006
VigVoodoo
Heres a troubleshooting guide also.
Warped
ok passed everything in that check list
karmakaze
Car: 98 240sx SE
i have heard of a problem with having the wrong ECU and only one cylinder firing.
Warped
here is the ecu i got with my motorset]
i have another ecu at home thats tuned by enthaply, can i just remove the daughter chip and basically have it back to stock?
VigVoodoo
Yeah try a different ECU.
Warped
alright well i'll try that tomorrow and get back to ya
Warped
Alright well i threw in my other ecu and it started right up
now i gotts try to get my ecu replaced ,even though im out of my 30 day warranty so we will see
Warped
well i cant get a ecu for the place for a warranty because im out by 20 days so my ? is now - I installed my 740cc injectors and my z32 maf and running the ecu tuned for them.The ecu is tuned for a bigger turbo but will it hurt any thing if im still running the stock t25 at 14psi till i sell my other car and buy the gt2871r
Warped
anyone? would it just run rich ?
Nicksemianiw
Car: JDM 89 Silvia K's
yea I am pritty sure it will just run rich as hell, a lot of fuel isint THAT big of a issue its the lack of that is. So I am sure it will be fine for a short while.
