cant find torque specs
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
For the girdle and crank caps... my usdm chiltons says 40ftlbs for the ca18de in pulsars... but can that be right?
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
I can't remember exactly, do the same bolts hold on the crank caps AND the girdle? I do know the crank caps should be torqued in proper order to anywhere between 33 and 40 ft-lb's.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
S13 CA FSM has them
Liquid_Neon
alright, took me forever but i found it. the caps are the same girdle of not. my usdm book said the same at 33-40ft lbs.
Got two pistons in... dam things are stiff, hard to turn the crank. They show no signs of marking anything up, but just seem stiff.
