cant find brake padwear sensor plug in on chassis 95 Q
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
where it be ?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It was dropped sometime in the MO. Neither of mine have it, one mid, one late.
jamesmost
maxnix wrote:It was dropped sometime in the MO. Neither of mine have it, one mid, one late.
mine did have them and i had them shorted out. when my jdm motor was installed i had the low pad warning come on and have not been able to find the sensors to short out.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
They are on the right front and right rear. I have the rear tie-wrapped to the lower control arm, and the front tie-wrapped back on itself.
I unplugged both leads, and used a wire to short the connection and taped the ends up. That way, I could always put them back, if I returned the car to stock brakes.
jamesmost
does the harness attach to the engine, could it be when my engine swap was performed that the harness was not on the JDM motor and not replaced off my origional motor by the mechanic ??
jamesmost
bump
jamesmost
the harness is just not there where does the harness plug into the chassis
