seaoharrwhy »
https://forums.nicoclub.com/seaoharrwhy-u144637.html
Tue Oct 06, 2009 2:34 pm
so i went to double check everything today. all my grounds are good injector plugs are good, spark plugs look fine, timing is good. So the deal is I went to drive it and it was running fine for about ten minutes......until i gave it full throttle. It is still only missfiring on cyl 3 and doesn't go away unless i let it set and cool off for a couple hours. 2 days before this started to happen i did bump up the timing to 25* and put 93 octane in it but since it started to do this i set the timing back to stock because i thought it might be the problem. any other ideas???? could it possible be a clogged injector, and what is a good way to check for that? please help, i just put money into my car and i wanna drive it.
