think AFORDABILITY!
...the KA is the best afordable turbo base motor to work with....there are some pro's and cans to this motor..let me explain a few.
Pro's:
#1.) replacment blocks start at $100. bucks
#2.)long stroke = torque
#3) full girdle for support of the crank mains under load.
#4) Valves are bucket over spring design..not rocker arm type.
#5) cam swapp is super cheep $30 bucks.
#6) parts easy to find of most ka powerd vehicle in a junk yard...unlike the SR or rb.
Con's:
#1.) rods oem suck for turbo builds...they need to be upgraded.
#2) headstuds are a must..rod studs bennificial aswell.
#3) you need a bigger maf and a ecu tune..
#4) pistons will not handle boost reliably..they need upgrading
even with the upgrades needed ..its still far cheeper to make 300whp with a ka than to buy a 200hp sr swapp...and if sumping drastic were to go wrong..you could allways pick up a replacment block for cheep..unlike the SR or RB platforms...all the guys on our team drift KA-T's or NA KA's..we do have a few rb guys..but there cars are allways down with parts on the boat from japan..ka-t all the way man.
