HashiriyaS14 »
https://forums.nicoclub.com/hashiriyas14-u11745.html
Wed Jun 01, 2005 5:54 am
Ok, I think that I can safely respond to this...
I have owned both a 5th gen Prelude and a 2004 WRX, the latter right after the former.
Firstly, I do *not* recommend an SH, go for the base model. It is nearly impossible to modify the SH's suspension in any significant way (i.e. shocks/struts, or coilovers). The SH has no real advantages over the base whatsoever, get a base.
Secondly, what do you want to do with the car? The Prelude is a *good* looking car IMO, one of my favorite 1990's automobiles. It is an excellent platform to build up as a show car for this reason.
It is NOT, however, in anywhere near the same performance category as a WRX. The WRX will plainly blow the brakes off it on a road course, and the Prelude is NOT an easy car to add horsepower to. You can get another 60-100hp quite easily on the WRX with only a reflash, turboback exhaust, and a couple of other mods.
The H22A has fibrous cylinder walls that make running any sort of boost without a serious engine build a very tricky proposition. Not to mention that it really wasn't ever designed to be a serious performance car, it's more of a GT.
5th gen Preludes are significantly cheaper than WRXs though.
The WRX transmission is not particularly enjoyable to shift though, mine was downright unbearable. it doesn't ruin the car, but it did somewhat hamper my ability to drive it really effectively. It is, however, a major bottleneck in terms of modifications. After about 300awhp, the transmission needs to be beefed up significantly.
All things considered, I'd say that if you plan to modify the car a lot, go with the WRX. It'll be expensive though. If you want something to just do minor bolt-ons too, not track, etc..., and something cheaper, go for the Prelude.
I know I rambled a bit, if you have any more questions, post them and I'll answer to the best of my ability.
