craze K »
https://forums.nicoclub.com/craze-k-u101699.html
Thu Aug 06, 2009 10:20 am
I had the same problem with my front driver door. Unfortunately I had to roll the window down and pry the interior panel down enough to get at the inside of the door. However before it completely shut down on me, I had hit the inside of the door several times to get it open, sometimes I used my foot to kick it. Brutal I know, but worked. It turned out to be the lock actuator went bad. It was sticking and that's why hitting it worked once in awhile. Since I didn't fix it when I had the chance, it locked up completely and that's why I had to tare apart my door panel. So maybe try hitting it first.(near the lock) There is also a topic on this site that tells you about a relay you can disable to get it to work again. Hope this helped alittle.
