neagan »
https://forums.nicoclub.com/neagan-u14470.html
Sun Apr 10, 2005 8:38 pm
See, that's the fun of eeking out performance and horsepower; knowing where you're starting from and where you want it to go. You need to research what the starting points of your engine's performance ratio's are first, otherwise you're wasting our time with useless questions.
That may sound harsh, but go back and read a few pages of some of the prior posts. You will find post after post of someone who wants to be hand fed all this information, yet they won't take the first steps to putting that information to work. If you're going to eventually pull the head to get ANY work done, shouldn't you be willing to figure out what your engine's baseline stats are?
If you're concerned about manipulating octane ratings then you still need to understand what it is you're starting with so you can modify just enough to ride that octane level fence without falling over it, yet close enough, so that if you want, you can add a can of '104 Octane Boost' to drive in the next level.
By pulling your head you will need to have it 'decked' before reinstalling it. That means some of the head surface material will be shaved off anyway. By knowing this info you can then decide what thickness or strength of head gasket you'll need.
From what was mentioned earlier, it just may be that all it needs is a good cleaning, tolerances checked and valve lash reset. \Also, you can learn a great deal about how your engine is performing if you go to the trouble of 'indexing' your spark plugs and learning how to REALLY-REALLY 'read' the plugs. It might give you a better clue as to why you think you've got low compression when your compression score variences are so close to each other.
Come up with a budget for the head and engine, and let's match that up with your1-3-5 year plan for the car. Then with that info we can truelly be useful to you. Hopefully this was a help and not a hinderance! Nitro
