canister?
BurnsAuto90
Car: 1990 240sx
1991 240sx
hey guys, what are the bennifits of using the canister for the vacume lines? what are the disadvantages? if i use it, could someone tell me where to vacuum lines go? and also if i dont use it, where do they go...?
srock srgreddy bovgreddy fmic
and those lines go....*drum roll*..
Nismo_Freak
Car: 89 Nissan 240SX
Can you explain further what you mean by canister?
If you are refering to a catch can then yes you should use one, and run the line back into the intake pipe.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
if you are talking about the charcoal canister, i dont use it. i had to hook the lines back up together. it is mostly emission stuff.
SpeedRacer1
Car: 1990 240SX, G35
One line goes from the intercooler piping to the wastegate. Another line goes from the throttle body to the BOV. The fuel pressure regulator and any boost gauge run off of another throttle body vac port. Cap any other vac holes (on the TB, intake pipe, etc).
BurnsAuto90
Car: 1990 240sx
1991 240sx
hey thanks alot speedracer1, yell at me if this is a stupid question but..you said that one line goes from the intercooler piping..meaning there should be a nipple ment for it, and all ive noticed is a large one on the cold pipe for the large rubber line and on the other side one ment for a bypass valve (which i was told i need to block off) so is there one im missing somewhere? (greddy spec-v)
SpeedRacer1
Usually you need to weld on your own wastegate vac nipple on aftermarket piping.
VectorVA
Car: Drifting
Couldn't you just tie into one of the vac lines running from the throttle body?
Found this threadhttp://forums.nicoclub.com/zerothread?id=122017
Modified by VectorVA at 11:01 AM 8/30/2005
Spins
Car: spending too much money on my cars.
Not trying to steal the thread. But on my blk top engine I just reinstalled a charcoal canister. My throttle body has 2 larger ports and 2 smaller ones. I ran one of the larger ports to the canister and one of the smaller ones to the canister. I capped off the other smaller port. I used the remaining larger port for the bov & wastegate. I tapped into the FPR for the boost gauge. The smaller ports on the TB won't work for a boost gauge. Everything appears to be working correctly. Did I do anything wrong?
BurnsAuto90
Car: 1990 240sx
1991 240sx
so whats with this setup with the lines, ive seen pics even before the manifold change and they still had a line running from the actuator directly to the throttle body?
ive got a manual boost controller and i was wondering if i did the lines like that...where would i put the boost contoller?
SpeedRacer1
Check the throttle body vac lines to see if they are getting any vacuum, one of the holes sometimes does not actually have a vacuum. The easy way to tell is to start the car and pull off the vac hoses on the TB if you feel suction then the port works.
You *can* run the wastegate off the TB, but Nissan had all three SR20DET's running off a mixed signal from the cold pipe and the wastegate control valve so I just use the intercooler piping as the source.
