slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Wed Apr 06, 2005 1:50 pm
Look towards the rear of the valve cover, near the firewall. You should see the engine room harness snake across the back. Coming off that harness are two connectors, about 2/3"x1/2" in size. The canister purge solonoid is the one on the right(drivers side). Make sure the connector is seated well, and that it has a locking-pin in to keep it in place.
HTH.-Jamie
