BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Wed Nov 25, 2009 6:21 pm
**I know you're Canadian, but I don't have a metric converter handy, so I'm writing everything in US miles.**
Just to emphasize what is mentioned above, it is true; ONLY Nissan certified technicians and service centers are qualified and have the proper fluids to service these transmissions! Even a cap-full of standard ATF will DESTROY these transmissions (don't believe us? read the many horror stores of people voiding their warranties and demolishing their $6,000 transmissions as a result of this very expensive "mistake!"). Unfortunately, for the time being, you're stuck taking it to the dealer. Also, the lifespan of this fluid cannot be compared to any "conventional" service schedule. CVT fluid is not subject to the high stresses and buildup of clutch material that causes ATF fluid to require replacement after 60,000 miles; actually, the onboard computer is supposed to determine the interval for you (bring it to your Nissan dealer; if they tell you to change it at or around 60k, bring it to another dealer for a second opinion; this stuff should last well into 120,000 miles under normal service). In the United States, a CVT flush costs around $500.
Another thing; Nissan has extended the warranty on these to 120,000 miles or 10 years, whichever is sooner. This is another reason it's important to just let Nissan take care of it; what Nissan giveth, Nissan may taketh away (for improper service).
