canadian 240's with VLSD???
Bobby_Wu
is it true that all Canadian 240sx's have VLSD's????...i saw it on 240sx.org's install page.
http://www.240sx.org/links/installs/lsd2/index.htm
Toahk
Car: 97 ....
Uhm think its a myth
wpg240
Car: Hockey
How do you tell. What the difference between LSD and VLSD. I have a Canadian 92 LE with ABS and it definately has lsd. Both wheels break loose under acceleration on ice or gravel
BadMojo
Car: 2007 Mazdaspeed 3
wpg240 wrote:How do you tell. What the difference between LSD and VLSD. I have a Canadian 92 LE with ABS and it definately has lsd. Both wheels break loose under acceleration on ice or gravel
AFAIK, the 240SX only has a Viscous Limited Slip Differential, which is a type of LSD. Unlike an Open Diff or a Clutch type LSD, the VLSD consists of two plates and...wait for it...a viscous fluid. If you wanted a clutch-type LSD, you would have to install an aftermarket one yourself.
sims
the V stands for Viscous, its the type of LSD 240's came with from factory.
it is a myth, i was told this for like a year to, and anyone on NWN(north west nissan, cnd 240 board) its not true, but LSD's are rather comon on CND 240's
wpg240
Car: Hockey
Yep thats one area that I know nothing about. But I did make it a point to test it and see if I had power delivery to both wheels
