can you use the ka lower harness
syndicatedreamz
my rb didnt come with the lower wiring harness i was wondering can you use the ka harness
FAST-DATSUN
that what we recommond you use!!!!!!!!!!!
Joe
FAST-DATSUN wrote:that what we recommond you use!!!!!!!!!!!
absoultley! its 10x easier with the KA lower harness.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
what about the knock sensors? and oil pressure sending unit? The KA24DE's dont have the exact same sensors at least to what i've seen comparing mine.
Joe
open the RB harness and remove that.
the knock sensors actually plug into the main Rb engine harness. so if you open the lower harness you only have to just pull them out of the mess of wires and they are on another plug that goes into the engine harness.
im not 100% sure about the OP sender, i dont use mine.
luckyrb13
Car: S13 240sx
Just take your oil pressure sending unit off the ka and put it on the rb and use the same plug off ka harness (should not have to be modified maybe extended. But if you wna to use hte rb gauge cluster and get the oilp gauge to work use the rb25 oilp sending unit which is the two wire one and you will have to hard wire one of them into your gauge cluster. I just went through alll of this ish its not really that hard. good luck
Kansei240sx
Thats freakin sweet! Thanks for the reply, ill have to keep that in mind!
syndicatedreamz
so what would i have to do. like i said my rb didnt come with the lower harness also my harness is from a 90 240sx
cvc9216
I have an extra rb25 lower harness for sale if you need it for the plugs
syndicatedreamz
how much
cvc9216
email sent
