at least we found the answer to the question me and u were talkin bout lol240z4u wrote:Thanks Ricky!
interesting, please do confirmNissan2367 wrote:The ecu you had Evan was a s2 wasnt it? It ran my car and it has a s1 in it...
this has been true in every rb25 that i have ran into, lets just say i have had some ecu woes lolCarl H wrote:iirc its actually the other way around...the s2 ecu will run an s1 engine but for whatever reason the s1 wont run the s2.its been a while tho.
Ricky, this dude was running a S2 ecu on an S1 motor. Ill clarify my post.Coolwhip wrote:hm, strange. As actual user experience has varied with the whole mix-n-match ecu and motor.
Evan, I guess the frying of ECU is varying as well, as the S2 motor I'm aware of running a S1 ECU has been running with it fine for over a year+ now, don't know if the issues lay in the way the harness was converted or what?
Yes just one box, same with aem.However the aem had a different ignitor dwell time for R33 RB25 and R34 RB26. Knowing the R34 RB26 coils are the same as R33 RB25 s2 coils, I brought it up to the aem engineers and I believe they updated the calibrations to reflect that in the R33 coil setup. So one has to wonder if the S1 and S2 coils indeed require different dwell times and the stock ecus are programed with different dwell times. Would it make a difference, I doubt it.Coolwhip wrote:+1, I agree Carl
Yet if anyone wants to be a guinie pig to try this out speak up :P
On a side note, aftermarket units get around this feat with one box, iirc the PowerFC has only one R33 RB25 unit listed, eh?
i have got a series 1 ecu to work on a series 2 motor but only after grand national coil conversion with igniterCarl H wrote:in theroy a series one ecu should work on a series 2 engine and vice versa...however there have been reports that it does not work.all sensor signals are the same only difference is integrated ignitors on the coils but even then the triggers are the same.
As in, "only after" the coil conversion or "this was after" the coil conversion?Had it ran with the S2 coils?matafied wrote:i have got a series 1 ecu to work on a series 2 motor but only after grand national coil conversion with igniter
Maybe not optimal and the off chance of buring up the coils or IC's in the ecu. What also complicates the matter is there are 15 MT&AT ECU P/N's for the R33 rb25.Carl H wrote:i would think that even if the coil dwell time was different it still would atleast fire, but perhaps not be optimal...right?
I think we're traveling further down the rabbit hole
But more actual insight like that is what we need!!! I'm liking this thread!
oh and ive done this also carl this is what one looks like after that happensCarl H wrote:or he tried to run a set of series 1 coils with a series 2 ecu...without an ignitor.that would fry drivers with the quickness.
Carl, he was using an ignitor.Carl H wrote:or he tried to run a set of series 1 coils with a series 2 ecu...without an ignitor.that would fry drivers with the quickness.
