can you use a 300ZX TT fuel pump on a NA Ka24DE?
eastreetmotorsports
Car: 91' Nissan 300zx Z32 TT, 72' Datsun 240z, 93 RX7 FD3S R1, 93' Nissan Xterra
been doing some reserach on this, is a 300zx TT fuel pump a straight plug in to the ka plug or is there rewiring needed to be done and is there a gain on PSI vs the KA stock fuel pump???? i know it can be used on the SR so i was curious, forgive me if this topic was discussed before but when i did a search i couldn't find a simular topic.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
eastreetmotorsports wrote:been doing some reserach on this, is a 300zx TT fuel pump a straight plug in to the ka plug or is there rewiring needed to be done and is there a gain on PSI vs the KA stock fuel pump???? i know it can be used on the SR so i was curious, forgive me if this topic was discussed before but when i did a search i couldn't find a simular topic.
As far as I know retro fitting it is possible. There are parts that will need to be changed such as the fuel sock and rewiring.........As far as I know you would need an FPR when using the TT fuel pump.....
2s4k0y09
Car: 1997 Nissan 240sx SE
Or look into a Walbro 255LPH FP, especially if your going KA-T in the future.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
There is some wiring and fabing up need to make it work,But nothing major.Pretty easy install..And the z32 TT fuel pump flows a $hi* load more fuel over the stock 240sx pump..You can run it on a stock ka with no problems at all...And no you dont need a different FPR,You can use the stock one just fine..
