Can you tune a stock sr ecu to use a N62 maf with a AFC?
S13-in-the-386-407
Car: 1995 240sx w/S15 conversion w/s15sr and GT30 = drift/show, 1993 Coupe w/s13sr equal daily
Location: Deltona FL, 32725 30 minutes from Orlando/Daytona Beach
I have done hours of searching and looking on various websites from the states all the way to australia and I can't seem to get a definitive answer on this. Let me tell you what I have going on right now and get you guys take on it.
I have a s15 sr20det setup that is pretty much completely stock except for the normal huge front mount setup with hks blow off valve, greddy boost controller and apexi super afc.
I am running my s15 sr with a s14 sr20det zenki ecu. I was having some idling issues and maf issues at first but have got those worked out. I am currently looking for a s15 sr ecu to install but don't have the $400 for it at the time that they are asking on Ebay or across the pond. Ok here is what is going on.
My s15 sr is supposed to run stock 7 pounds and it runs great at that. I should be able to boost at least 15 pounds pretty safely for the time being before I get my new ecu and a tune once I get a few more bolt ons. Well anytime I try and boost over 10 - 11 pounds it starts to cut out really hard at high revs like I'm hitting a fuel cut off or something.
Could this mean that I'm maxing out my mass air flow sensor? I have talked to a few people that run really huge sr setups and they have all came to that conclusing. The s15 sr engine setup is supposed to be around 250 hourse power stock and and a s14 sr setup around 215 or 220 I believe. So i'm guess with the front mount and bigger better turbo of the s15 engine and bigger injectors being 480cc that if anything around 10 pounds or so I should be getting pretty close to 300 horse power at the crank along with the fuel map that i'm ajusting with the afc.
could this be to much for the stock sr zenki maf?
If so here is my question... Can a 300zx n62 maf be tuned with a afc to work with a stock ecu smoothly without getting a real tune for the time being? Before when I didn't have the correct maf for the ecu I tried wiring in the n62 and at idle it was running so rich that it was fouling out my plugs. Can this be fixed with the afc temporarily or will I have to wait until I can get some dyno time?
On another note i'm for sure getting enough fuel because I have intalled a walboro fuel pump and richened up the fuel map with the afc using a wide band.
Please let me know what you think and let me know if you need anymore information about my setup or if I have left anything out.
Discuss.
