Can you replace 2006 gauge cluster with 2008 cluster?
scchuck
Car: 2006 M35x
I really don't like the orange gauges in my 2006 M35x so I was wondering if I could swap the cluster with the blue/purple gauge cluster of a 2008 or newer. If so, my 2006 has adaptive cruise and lane departure alerting system, does this also come into play? Would the 2008 cluster have this by default or were the gauge clusters different depending on options?
Thanks
Steve
KoMikeey
Car: 2007 M45 S, Aero kit, Diamond Graphite, Uprev, Injen CAI, G37 sport vlsd differential swap, Full custom exhaust (removed secondary cats) into an x pipe through the megan exhaust.
im pretty sure they will still work because your only changing the cluster, but it wouldnt match, cause rest of the car is still orange/
scchuck
Car: 2006 M35x
Thanks!! Sweet looking M!!! What kind of springs did you use?
Steve
KoMikeey
i used to have d2 racing coils, didnt like it and went back to tein S tech springs. the roads here are horrible.
and thanks man.
daurislittle
Car: Infiniti M3 Sport
Nissan Altima Coupe S
Did you end up change the cluster? If does it work still. I changed out the ac controller with 2008 and it failed terribly shm... I was thinking of switching the instrument cluster as well if there isn't any conflict
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
People have done it successfully
2007infinitim45s
Car: 2007 Infiniti M45 S
What do you mean by failed terribly? I just ordered a 2008 ac as well cluster to try to swap it out
2007infinitim45s
2007infinitim45s
daurislittle wrote:
Mon Nov 26, 2018 11:35 am
So you weren’t able to change the temperature controller ? I’m swapping the one on my 07 with an 08
J.Rm35
Car: 2006 Infiniti M35
I did this 5 days ago. The cluster and clock are plug-n-play. The ac nav board won't allow the features to work. As I've gotten into it, it's a lot of switches out the front door sills are plug-n-play. And the steering wheel it's that freaking ac board that's the problem. I've purchased an '08 ac module to try, but haven't installed it yet. I will let you guys know.
Reason: TYPO
LIBRILZ
2007 M45 Sport
J.Rm35 wrote:
Sat Aug 15, 2020 5:31 pm
Thanks! Thus far im aware of folks swaping LEDs and that working
