A while back I glazed over a good Spec clutch because I had my clutch pedal adjusted wrong and was slowly riding the clutch all the time. (You live and learn.) The clutch surface is as smooth as glass now.
This clutch has a lot of meat on it, but is glazed over. Can it be saved? I was thinking about sanding it down a little to remove the glazing. Would this work?
I don't like to take shortcuts but if something can be fixed with a little elbow grease I'm all for it.
Here are some pictures.
Thanks,
Darian
