Can you interchange Cam Caps with different heads? HELP
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Like the title says, is it Safe?
dickie
Car: Killer Turtle
can you elaborate?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Generally, absolutely not. Any bearing cap/half that has been line bored with its counterpart should only be used at that location.
That said, if you are in a situation where you must use another cap (say you lost one), then you can get away with it provided you find another that seems to fit perfectly.
With nissan engines, you can get away with this, but it should not be a common practice. I wouldn't recommend doing it with anything but the cam bearing caps.
You should remove valves, valvesprings, retainers and buckets, then install camshaft with all of the caps that you plan to use. Torque to spec and make sure cam spins freely.
^ Long time no see!
Welcome back, Gabe!
