blackmax23 »
https://forums.nicoclub.com/blackmax23-u66692.html
Tue Mar 18, 2008 2:54 am
That tin can sound is NOT coming from your mufflers or your pre-cats. That's the notorious sound of maxima's with a bad flex section in your y-pipe. You might have a leak. In some aftermarket y-pipes, the manufacturer makes a good quality pipe, but awful flex section and you get that sound. If you go with a new y, go with one with a lined flex section so you stay away from the "bees"!
Also, even though you have a CA spec emissions max, meaning it's at least a 1999, doesn't mean you have to pass a CA emissions test. I don't believe where you're at, in New Hampshire, has any emissions tests. Even if they did, you would still pass with an aftermarket y-pipe, as long as you let your car warm up to operating temperature. What the pre-cats do is heat up the exhaust when the engine is cold so the cat can do it's job. But the cat can't do its job if the temp's aren't high, so the pre-cats heat it up. I have never heard of any SES or CEL coming on because of the y install. I have a Warpspeed ss y on mine and I love it. Amazing sound and great power from 2500-redline.
If you get just the y-pipe, you're only replacing bank 2's pre-cat, not bank 1. If you got the full header and y-pipe, then you'd be replacing both banks. Not really sure what the real gains are if you go with the headers, I've heard another 5-10 at the crank, but don't quote me on that. I would recommend you get an o2 simulator and stick them on the y where the pre-cats would've been once you get your new y, just as insurance that you won't trip a code. Good luck, let us know if you have any more questions!
