can you clean injectors?
jivehonky
Car: turbo 240!!
in my 1991 240sx ka has an injector that is not firing. i got it to work for about 20 miles just by switching its cylinder. can i clean or fix it some how? or do i have to buy a new one? can i buy just one or do i need to buy a set of 4? cheapest price? should i get one from nissan or should i buy one from somewhere? if i JUST get the 10% bigger injectors will i get more horsepower?? ( if i did that i would get a whole set)thanks!
NateDogg
Get it ultrasonically cleaned. I did and cured my hardstarting problem
jivehonky
Car: turbo 240!!
how much did it cost and where? i live in NE.... the middle of nowhere....... the only good part is less people= less cops.... and less poeple to race :(
stickgoat
Running a top engine cleaner through a main vacuum line should help (if not entirely) clear up those types of problems... It'll clean out the carbon deposits and other nasty stuff that accumulates, and blow it out the exhaust.
Most shops that deal with preventative maintenence should have a service like that available...fuel injection cleaning. I know the one at Jiffy Lube costs $59.99...just for reference.
Stock-S13
well if you want to buy injectors i have a web site has oem parts for cheap cost me about 80$ for a Head gaksket kit...
http://www.importspartplace.comdid take a while for the transaction itself to go through kinda fustrading but cheap none the less-edgar
joe_keyzer
What type of cleaner do you use on and you mean just run it thru the main vac line on the power boost for the brakes?
-Joe
WDRacing
Get them ultra'd like Nate said. Its a good investment. While there out have them flow tested and put the highest flowing injector in cylinder #4.
WD
