Can you check the resistance for me please
Rubyz32
Car: 90 n/a z32
No mods as of yet
Anyone with a multi-meter and a couple minutes, I need to be sure of something and I can't find it in the fsm (probably not looking hard enough).
I need to verify the resistance of the pos. wire that goes from the positive terminal to the fuse link. Thanks.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Should be a direct run with no resistance.
Rubyz32
Car: 90 n/a z32
No mods as of yet
So if I'm getting 3.6 at both the fuse link (1 post to the other) and the wire then I've got an issue? Thanks ace.
Ace2cool
What issue are you trying to track down? Theoretically it should be 0, but 3 ohms isn't exactly a large amount.
Rubyz32
Car: 90 n/a z32
No mods as of yet
Well, a couple weeks ago, my starter fried and the car died. I couldn't get it start back up so I had it towed home. I then proceeded to pull the starter and replace it with a new one, but as I was removing it, I realized that the insulation on the positive cable had melted. I ordered a new set of battery cables and once I got them installed, the motor continued to rotate very very slow. Similar to a dead battery. I'm in the process of pulling all the plugs to try to rotate the motor by hand. I'm thinking the timing belt broke because when I tried to start the car after installing the battery cables, the motor seemed to only spin a quarter or so revolution. I watched the crank pulley while I had someone try to start it.
Rubyz32
Car: 90 n/a z32
No mods as of yet
Update:
I pulled the upper timing cover and the belt looks fine (not broken). It does seem to have more slack than what I know from my z31's. Also, when I push on the belt, the tensioner moves. Is that right? The motor is definitely stuck where it's at. I can only rotate the motor about 15-20deg. I'm thinking the belt slipped. In order to check the belt alignment I should try to line up the marks at tdc correct?
Rubyz32
Car: 90 n/a z32
No mods as of yet
One more question. Could I be looking at a broken clutch or maybe the clutch fork?
