LongBeachCoupe wrote:deduct information on this adapter, and post it here!
this is what i found on them talking about it, but no link to the actual adapter...
PART 1 - "When you take off your stock shift knob, all you are left with is your shifter arm. Well what you can do is buy a manual shift knob, we will go with sparco because thats what I have on mine and it will work the same on your auto, and the sparco knobs come with an attachment that has 3 little screws on it
You place the attachment on top of your shift arm, screw in the 3 screws tight with an allen wrench, then on the top of the adaptor, there is a little threaded knob that sticks off, and you screw the actual shift knob onto the adaptor
wait i might be wrong, if there is the shift lock mechanism on your auto, you might have to disable it, or cut it off with a dremel, auto guys help me out here"
PART 2 - "if you cut the auto lock mechanism on the top of your shift lever, then you can get anyone you want, but just remember, if you do that, you can easily move the shifter into another gear without pressing the release button so i would NOT recommend this at all"
I also read that some MT shift knobs come with a spring and when it was time to shift on an automatic car, all they did was press down and shift. That the pressing down did the same action as the button on an automatic did.
Modified by srwong at 5:06 PM 7/26/2009
