can wrapped rotors cause bearing to wear out
D_roc
Car: 2001 Maxima 20th aniv edition
just wondering co i have 136k on my car and the front wheel bearings are wearing out, and i replaced the driver side first and it got destroyed within 2mo's. so just wondering weather wrapped rotors can cause this. because when i brake the steering wheel vibratesthanksD
DevonD
Car: 96 Nissan Maxima SE
Yeah I would imagine that would wear them out faster. have you changed your rotors? you should do it soon if you haven't. and its really easy and cheap to do yourself. probably only take an hour or two.
when your slowing down with warped rotors the brake caliper is mounted to the spindle pretty securely and its not going to move. something has got to move and give way to the vibrating so its probably the rotor. and wiggling it back and forth like that could destroy the bearing I would think.
This is just my guess though.
D_roc
make sense man thanks, guess it is the rotor that is causing it.thnaksd
