240crawler »
https://forums.nicoclub.com/240crawler-u29033.html
Fri Mar 17, 2006 5:33 am
I tried every place imaginable, and could not find a metric plug that size in stainless. So, as I could not get the EGR bung out of my cast manifold, I used the AIV bung in the EGR. I simply left 3 inches of pipe on, and put a tight kink in it. No leaks yet. I still needed to block off my AIV, so after searching for like 4 hours, my drunk brother finally told me that on an s13 the o2 sensor is mounted in an adapter that has the same outer threads as the EGR and AIV. I took out the adapter, and voila! I simply had to put 5 nickels behind it, as the threads are only 10mm deep, compared with the hole at maybe 16mm. Also, please use PB Blaster or comparable product for 3 days before on all manifold fittings and bolts. You will smile when taking them off. I used anti-seize on all of my header studs and EGR/AIV fittings as well as o2, just do not get any on the ceramic part of the sensor.
+1 for an alcoholic brother that hates rice cars but knows everything about them!!!!!!!!!!!!
