timothy.kelley86 wrote:So I have an 08' M35 Base, lowered with the Eibach Pro Kit, and adjusted back to normal alignment specs with the following:
Eibach Adjustable Upper Control Arms
Eibach Rear Camber Kit
Eibach Rear Toe Arms
I get an alignment, my car drives straight for 3 weeks, and then I am back to an exaggerated pull to the right. Is it these nasty New England roads? Could struts be a factor? Are the adjustable parts more prone to get whacked out of spec? Is there anything I can do to fix this problem permanently? Will my 15mm spacers help this problem (once installed)? Thoughts?
get the front and rear sway bar links and front outer tie rods replaced. Depending on the life of your front struts, you may need to change those out as well. once you get those in place, you should be good to go....makes a big difference.
