Bigvinnie wrote:...but me personally I am into bore and stroke. I don't mind the rev and 2.4litre's it is a pretty strong vacuum/ air pump.
Is that the responce you were looking for?
Bore and stroke is fine...it just that with the KA's stock stroke, you simply CANNOT run +8000rpm for extended periods with STOCK rods...no matter how well you prep the crank...and no one addressed that in the other forum's thread.
Someone brought it up, but it wasn't given a single reply...everyone just looked over it.
They were all over the crankshaft balance issue...which is a concern...but not the whole problem.
And the response I was looking for was how you were going to keep your stock rods from snapping at rediculous piston speeds...which you indicate now that you'd look into forged rods (possibly with shorter stroke)...which is fine...
...but it was just never brought up as a potential problem. I was just asking why it wasn't given due consideration.
- Brian
