DRIFTEADOR »
https://forums.nicoclub.com/drifteador-u23379.html
Wed May 18, 2005 10:25 am
street tune to 12:1 afr full boost and trim timing 1 degree (91oct), .75 (93oct), or .50 (110oct) per lb of boost. for example, where timing is 25btdc stock, it'd be 15btdc at 10psi on 91 octane. btw, this is a lot easier to do when tuning via manifold pressure as opposed to airflow. anyways thats your basemap. then go to a dyno and see what makes more power without detonating. slowly increase timing until no significant power is made, trim back and leave. same if spraying h2o/alky...increse timing and leave the afr alone.
idle and cruising, if you cruise in closed loop (sensor feedback) should be stoich, 14.7:1; your ecu takes care of that automatically. once load reaches ~-10in. Hg, the ecu switches to open loop where it reads off your preset/tuned maps. I'd start from 13.5 at the lowest load point, 13:1 at athmosperic pressure (0 vac/0 boost), 12.5:1 at 3psi and work my way up to 12:1 at full boost. sounds easier than it really is though. for every cell of load vs. rpm, you have to plug in a different value to achieve the desired afr. the emanage, for instance has a 16x16 scaling, thats 256 different cells.
running rich and retarding timing before boost will make it spool faster, in fact thats how full boost launch systems work (have you tried it yet fiz?), but if you don't have it setup as a 2 step, if its just rich and retarded all the time, you'll be sacrificing driveablility out of boost and possibly turbo life.
