Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Oct 26, 2005 2:34 am
Let's try beating a dead mule for a while, for a change
I am still waiting for my SS lines. When they come it, I will take some pics of the calipers, connections and lines for you all.
Since the factory lines have banjo type connections, that require a very clean smooth surface to seal, and the Z32 calipers have a flared fitting with a rough cast surface on the caliper, I would be hesitant to use the banjo fitting, even if I had new brass washers.
If I was insistent on using the factory lines, I would be inclined to have the connector surface machined first, to ensure a very good seal. This would cost much more than the SS conversion lines.
Another thing is, you wouldn't have the added pedal feel of the harder SS lines with the factory rubber lines.
Either way you go, you really need to replace the lines, since 12 to 15 year old brake lines are about due for replacement. I bet the factory lines cost more than the conversion SS lines.
-more deceased equine abuse
