DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Aug 07, 2005 7:44 am
yeah, but if the bearings have gone bad water will be leaking through the weep hole, otherwise you better look elsewhere for your problem
so start running the engine and look for water coming out of one of the two holes on the water pump, otherwise your water pump is probably tip top
