Postby
Holvinator »
https://forums.nicoclub.com/holvinator-u138020.htmlFri Sep 10, 2010 7:15 am
Spoke to the guys from Z1Motorsports.com and they said that my calipers are aluminum R32 Calipers (the 32mm ine) and supposely this brake kit will work with those calipers I have (here's a link) http://www.z1motorsports.com/240sx/prod ... ts_id=4577
So I wanted to confirm with you guys if my calipers really are R32 32mm in aluminun? How can I tell if they are alluminum? all I know they are heavy as $h!T lol Get back at me guys Dont wanna spend about $600 on these and then they wont work.
If they're "heavy as s***" they're cast iron Z32 calipers.
Those pics suck. Better pics would help us ID them.
Regardless, those should be fine with the larger rotors. I'm running the SPL big-brake brackets with Z32 aluminum 30mm calipers on a Z33 Track Edition rotor.
No man. They are not Z32 Calipers. Ill take better pics when it stops rainning. I bought Brembo rotors for those calipers that cost me an eye ball because everybody told me that my calipers were from a Z32 TURBO. Those rotors wont reach all the way up to the brake pad; so there's about 1/8 of the brake pad is touching the upper part of the rotor creating this anoying sound like if u were running out of brake pads.
Im supposed to be using a 296mm x either 30mm or 32mm rotor but I really dont know and thats what Im trying to find.
