can u pull a 01 frontier engine without pulling the trans, if so how?
prolandco
Car: 01 nissan frontier 4x4 crewcab, 08 G37, 07 G35X
I have everything unhooked but cant believe nissan didnot leave an acess panel on the bell houseing, this is my first nissan and they are alittle different to work on, any advice would be nice. how to acess torque converter without taking the oil pan off? This just seems crazy to have to take an oilpan off to pull an engine
Brandon93240
Car: 1993 240sx
There should be an access panel that comes off at the bottom of the bellhousing, I haven't pulled an engine on a frontier in a while, if there's no access panel then you can usually get to the bolts from where the started bolts up, alot of Jaguar and Mercedes are like that. If you want you can post your email address on here and I'll email you the service procedure from alldatapro.
prolandco
Brandon, thanks very much [email protected] is my e-mail, any help would be greatly appreciated. i can't see a access panel and the haynes manuel doesn't help, so thanks again for anything u can do.
