Can titan 5.6l with 5sp auto fit in a j3o
Cathode
In know they came in v8 in japan. Which model number was the 4.1l v8 and did nissan ever bring it to america. I also wanted to know if a 300z or q45 multilink front suspension swap be a good idea if you have to cut the struts out to make room for 5.6l v8?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
They pu the VH41 in the J-ferie
I dont see how you coudl swap onthe multilink suspension.
Cathode
you can't swap, but it is the same technique they use on first gen mustangs to turn them into big blocks. The strut towers are too close so you have to cut them out then install new front suspension. It is just that the z and q are finally cheap enought to be doners.
