can tie rod ends fall apart?
240esseckz
Car: 1990 240sx ka24det, 479whp, 504wtq...1995 180sx in progress
my tie rod ends are really worn out...the ball joints are worn to nothing...they spin around indefinately...and i was wondering if its possible for them to snap...fall apart...i know it would be real dangerous if they did...the steering is also real loose...and i know its probably from that...
180fan
Car: 89 fastback
Yes, like all metals, if you exert enough pressure, it will break. If there's enough play in the joint, you're asking for a breakage as there'll be that much leverage for the opening to apply on the threaded section. Tie rods are not expensive to replace anyway. If it's worn out, replace it.
